Hey guys - I have a question.............
Thru tons of diagnostics, my fuel pump seems to need replacing...........truck will start and run just fine, and then when it is shut off for 5-30 minutes, it will not start. Testing shows the pressure is about 17-19psi. Should be about 35psi. Natch this is a KOEO test. Previous tests when truck is starting just fine, KOEO pressure is 35psi and KOER is 47psi.
I let FORD test this truck and they said that it is the fuel pump that is causing this prob. Tested the relay and it is good, the 20A fuse in the PDB appears to be ok. Are there any other fuses that could be shorting out???
Anyway - question is - should I use a motorcraft pump assy or is there another suitable mfg for this.
any words of wisdom will help.
thanks
thanks
