extended half cab
bigbluebronc
ca
I have an old semi rusted full top, but the whole top it too heavy for the suspension I have set up, I am cutting a whole top into a extended cab half cab, cut weld see how it works. Whatch ya think ? Little toyota side windows and such...
Why not...! Sounds good....
The old Ford Courier had such a top....kinda the pre-runner to the extended P/U cab.
As far as weight reduction....I would guess 30-40 lbs. Assuming its closed in..
Propane is good for all day use city/govmt. veh., like mail trucks., city serv. with a home base re-fill tank.
You trade off some power & range....depending on location of re-charge stations.
bigbluebronc
bigbluebronc
ca
Why not...! Sounds good....The old Ford Courier had such a top....kinda the pre-runner to the extended P/U cab.
I lost 140 lbs on my scale but will put about 30 back on with plexy windows and weld material
BBB
Broncoholics
Broncoholics
Washington State
My fiberglass half cab probably weighs 20# or less.
If you need less weight in rear, I'd go fiberglass. The down fall is evert tree you hit cracks the top. The up side of that is its easy to repair.
Sandoval_broncosauria
