wont crank
rickco
when i try to crank the 88 bronco 11, the fuel pumps wont com on i replace relay and if i jump the pumps out and pump fuel up it still not cranking. can it be put on a computer to see what wrong with it
timster24
CEDAR RAPIDS, IA
you could stick it on a computer but may not show whats wrong with it, I would trouble shoot your ignition switch or tumbler first. sounds about like the truck dont relise that you are trying to start it for one reason or another.
timster24
CEDAR RAPIDS, IA
oh yeah if its an auto check the park/neutral switch. if that is broken the truck may think it is still in gear, therefor will not allow the engine to crank over
