Windshild
Hay Jumper., welcome..!
If it's crudded up., you might want to put some **** on the piano-hinge at the bottom of frame.
Then., with the hardtop detached fr. the top of w/s frame.,(may have to remove bed-rail bolts to allow clearance) tilt the windshield down onto a thick blanket,etc.
This gives you access to the rubber seal & the bolts that hold it on. May need some **** juice there as well.
There should also be a rubber seal on top of the w/s frame.
northernleitz
Northwest AK
My windshield frame was held on with spot welds ... at least thirty of them. If that is the case with yours you will want to really clean it out under the hinge with a wire brush or wheel, then get a good spot weld cutter, shine some light on it, and get to work.
fred tyler
