Vibration
biggnat79
I took my bronco out tonight after I finished putting it back together, and noticed some new vibration that is causing the whole body to shake. It only seems to do it when I accelerate from about 15mph-30mph and when I let off the gas it does it but not quite as bad. It wasnt doing this 2 days ago, and the only thing Ive done it replace some gaskets, coolant hoses, and the pipe that runs from the lower intake manifold to the EGR sensor. I didnt hit any big bumps on the road, or accelerate hard, so I cant imagine what would randomly cause the vibrations. Any suggestions?
biggnat79
no, the idle is very smooth, but it has significantly less power.
zakcode
i would go back and check for a vacum hose you might have bumped off or a leak around the gaskets. sounds like a vacum leak to me .but im not a mechanic. "loss of power" is the big sign.
fred tyler
