u-joint woes
stillrattlin
Hello-- New to Zone-- have a 67 ford bronco 289- 3 speed manual tran-- Rear drive shaft yoke (coming out of T case) not broken but the pieces that bolt to it (dont know what they are called-- straps?) (they do not look like the straps that hold the end of the u-joint at the rear axle) and bolts were severely worn when u-joint failed. Are these available new or is it a junk yard- used item only-- On the end I am describing the bolts pass through the back of the yoke and thread into these "straps"-- there is not much thread left on them and I do not want to put it back together in such a weakened condition. They have a raised metal end where the u joint cap fits in the journal to keep the end caps (with the needles in them) from coming off. Maybe if I knew what they were called I could find some new ones. Would prefer not to have to pull the yoke-- maybe that is only option. Any help would be appreciated.
Many thanks--
Hi Rattlin.., welcome....
Pics would help....
Hmmmm..., not sure if what you have is stock fr. that discription...? :unsure:
Go to (don't know where you are) Toms Bronco Parts., Wildhorses 4x4., or this site sponsor Jeffs Bronco Graveyard....
Their websites will have pics & the parts you need.
Do fill in your info on this site for more accurate help. B)
S
stillrattlin
Many thanks--
We have had this bronco since it was new- apparently the Borg Warner style yoke needs to be updated to a spicer style yoke and a new drive shaft with CV joint installed-- apparently the old one was "modified" cv was removed and drive shaft modified and hooked directly to the t-case-- It has run a long time like this without significant problems but it would be nice to fix it correctly- It would be nice however to find some Borg Warner "straps" and bolts and fix it while I raise money for the new drive shaft with cv and spicer yoke--
That's what I thought..
Still not much info as to where you are or how you use your rig... but., you could stop by your local driveline shop & see if they have any used/re-built shaft set-ups.
The Borg yokes my be fine, depending on your usage....& they may be able to put you back to stock (meaning 3 u-joints/CV joint & correct length) at an attractive price.
ALSO.., assuming your front shaft is stock...?
S
stillrattlin
Thanks--
I spent part of the day under an old bronco spraying Blaster on the rear drive shaft bolts-- It has spicer yoke- cv and the price is right-- Should bolt right up to mine-- take Borg yoke off my t-case and put "new" spicer yoke from old bonco on mine-- Just not looking forward to taking yoke off of junk bronco where it sits. (or the one off of mine for that matter)-- is this a matter of impact wrench Blaster and "tapping" (maybe some "gentle" heat)?
S
stillrattlin
Thanks--
PS
My rig is basically bone stock--
Have you looked/measured the rear (rear) yoke on the rear end..?
Best to have both yokes the same.
Those nuts have a torgue setting....you should be able to back them off with a breaker bar. You may have to bolt a chain on the yoke to keep it fr. turning.
Closely insp. the nuts.... they should fit snug or they'll loosen up causing wobble.
Best to replace if they ***** on loose.
stevedave
