Trans, Tires gear ratio help
mikeiam82
Kelowna, BC. Canada
Hi, i recently purchased a 1969 bronco with a 68 body and im looking for help in the gear ratio transmission and tire combinations. Im currently planning on swapping in a 89-93 302EFI/NV3550/Dana20 combo for the main drive train. I believe the bronco has 3.50 gears but theres no tag and the wheel turn test has been inconclusive (2 turns of the tire turns the driveshaft 2 and a bit). I was using the gear ratio calculator on grimmjeeper to determine what would work best and i was thinking of using either 3.70 or 4.11 with 33's.
So to sum it up 302efi/NV3550/dana20/3.70 or 4.11 /33's. This is going to be used as a 80% highway and 20% off road and i was wondering if there was anyone here with any experience with this setup or 1 similar that could tell me how this works. This setup would allow me to run at these speeds:
50kph 2nd- 2700 rpms
3rd- 1650 rpms
80kph 3rd- 2600 rpms These specs are with the setup and 3.70 gear ratios.
4rth-1899 rpms
110hph-4rth- 2611 rpms
5th- 1906 rpms
Theoretically to me this setup would make the best for passing power/cruising for optimum mpg for the road.
Any opinions/criticisms/and words of encouragement are greatly appreciated.
Hi Mike.!
Looks like you're way ahead of most of us. And., you've done your homework. :-B
All I can add is the lift (body/suspension) is involved in tire size., along with fender-wells.
As I recall., "Posi" req. both wheels off the ground for ratio test. Open dif. req. one wheel on the ground to get correct count.
Chalk mark the floor & bottom of tire. Chalk mark the dr. shaft.
One rotation of the wheel should give you 3 1/2 rotations (350's) of the dr. shaft.
4+ a little = 411's & so on.
I'm guessing you have 411's
Do fill-in your sig. & keep us posted...pics as well..?? >:D< <'>
M
mikeiam82
Kelowna, BC. Canada
Hi Mike.!
the tire rotation test was the same with both wheels lifted and 1 on the ground, ill be yanking it apart soon and ill count teeth to be sure. 2.5inch suspension and a 1 inch bodylift are also planned. I posted some pics but im not sure where they went <_<
I cant wait to get into it, ive been working on cars and trucks for 20+ years and been a bodyman for 11 years. I know you dont start nothing without researching first
Hatu
Santa Clara, Utah
3rd- 1650 rpms
4rth-1899 rpms
5th- 1906 rpms
I put a NV3550 in my 69 Bronco with a 302 and did the math to figure the right rear end ratio.
With the three speed standard trans a 3.50 rear and 32" tires you get the following: At 3000 RPM you would get 81.59 MPH.
With the NV3550 and it's .78 OD 5th gear, you need a 4.56 rear gear to get close to the same RPM and MPH; with the 4.56 and 3000 RPM you would get 80.3 MPH.
I'm changing my rear and front axle to 4.56, should be great for crawling as well as the sand!
M
mikeiam82
Kelowna, BC. Canada
Thanks for the info
M
mikeiam82
Kelowna, BC. Canada
I was just running over these number again and i totally understand what you are saying, with your setup up you run 4.56 for low end torque and power for the dunes. At the 3 speeds of 30-50-65 mph you would be running at 1900-2300-2200 rpms so highway speeds would be achievable without screaming down the road. I on the other hand am building a DD for the road and mainly summer driving ( up here in Kelowna B.C. summers are like Californian and winters are like Alaskan ) so by running 4.11 ill be bringing the rpms down to 1750-2000-1950 at 30-50-65 mph and buy running 3.89 it will come down to 1650-1950-1850 at 30-50-65. I know these are the U.S.A.'s main speed limits and these translated over to kph are 50-80-110 which are our main speed limits so it should work out great.
I value the info you've provided, its helped me visualize how the bronco will actually respond without actually testing and spending money figuring out whats best. I figure by upgrading the engine and transmission from stock expecting better performance than stock should result. Judging by this I will probably run the 4.11's being as thats what is most likely in the bronco and if i have to upgrade to 4.56 it will be a minimal cost.
stevedave
