escortwgn
I knew this was coming for a while now but it finally happened. Traveling to Florida from South Carolina to pick up my Mini Cooper from it's repairs. Had to keep refilling the engine with oil at every gas fill up, approx 150 miles. Used 4-5 quarts going down. The carb back fired 4 times rapidly and was unable to travel less than 1500 rpms or 15 mph. Once it cooled the oil was now over filled.....Put the trailer on warmed up the bronc increased idle and put a tool box on the gas pedal to keep it running. it was missing a back firing out the tail end. At a stop I had to press the gas and brake at the same time to prevent a stall. Made it home to South Carolina in one piece while traveling through bad weather back on the 17th. Following morning while unloading the car and prepping to return to trailer, I had no oil in the engine. It was all over the driveway, the rear main had given way. Not sure what all to make of this but the new 351w will be installed this coming weekend and i'll be going through the old engine to see if it can't be salvaged. I'll try to post my progress on both the install and hopefully the restoration of the old.
