Tailgate window
tiggrowe
I got an old 83' Bronco that I am redoing. All electrical is unhooked, what is the easiest way to get the rear window down?
Hook a jumper wire from a 12V battery to the two wires just before the window motor. IF you remove the inner access panel on the tailgate, toy will see where to go. BY chance if you get'em backwards, just switch the connections. This assumes the motor will still work.
kyleh01
