JLasvegas
- Joined
- May 25, 2008
- Messages
- 204
- Reaction score
- 0
I have noticed some squeeking when driving at slow speeds, like going over speed bumps
I also realize that some is normal, but I noticed that my extended radius arm bushing is cracked on the passenger side, just below passenger door underneath where the bolt and the washer meet up with it against the bracket, the bushing looks like a white urethane or plastic type of busing and you can see a pretty good size crack in it and it isnt sitting super flush like the drivers side
can this bushing be found by itself "I had no luck on google " and if so it should be a simple remove nut and replace and re tourqe correct?
