specs
Bronco in Germany
Nuernberg/Germany
i figured out some informations about my bronco, but i could not find the axel.
:huh: does anyone know ?
greatings from southern germany
Axel Code B9 ???
S_bolt19
Colorado
Looks like you have everything correct with the exception of the color
Color: E - Sky View Blue
The Axle code, B9, is for 3.50 gearing with limited slip & the 3300# rear end. The stronger rear end of the ones offered, but with the highest gear ratio.
You are correct again. The Bronco has a DANA Spicer front end. If the gearing has not been changed, there is usually a tag held on by one of the differential bolts with the codes on it.
MUZZALL
Ellensburg WA
If your front end is a D-30 and you plan on running your Bronco hard you should upgrade to a D-44 front end.
Sandoval_broncosauria
