Seatbelts
Karl Ray
Indiana
I have recently purchased a 72 bronco. There are no seatbelt front or back. The only trace I can see are a few holes in the floor board on each side of the font seat. I am not sure how to mount new lapbelts. Do I just ***** bolts into those holes, or is there some type of mounting bracket? Also on the rear, I see no holes...maybe I am not looking hard enough. Any recommendations on how to mount rear lap belts? Any help would be greatly appreciated. Kids are dying to take a ride.
Thanks
Bronc76
There should be two holes on the back side of the front seats. The belt bolts should ***** into the holes.(the spring loaded or retractable belt side are mounted on the door side) There are four bolt holes behind the rear seat. the bolts should just ***** into the holes.
If you are looking for belts and hardware, see Jeff's Bronco graveyard our sponsor http://broncograveyard.com/bronco?search=seat+belt . He offers a 2% discount to member of the Bronco Zone when ordering on line. Enter discount code BZMEMBER and include your BZ user name in the order.
The rear ones should be real obvious..., if not, they may have been filled in.
These belt holes are welded-on nuts & reinforced....way better than making your own.
They req. somewhat special bolts.. i.e. high thread count & usually req. a "star" type allan wrench.
Recommend cleaning the holes well, especially if the bolts have been out for a long time.
A Dremmel with a small wire wheel works.
If the rear is filled with hard filler., punch it out carefully as the tank is just below.
If you have a rollbar., you can get the set-up with the (front seat) shoulder restraint.
Like Seabronc says...best to use a supplier who deals with these items so as to do it once only.
Gary wilder
