Replacment ignition system.
BronBronBronco
Santa Clarita,CA
I have a 69 Bronco with a stock 302. Distributor is the old point style & is leaking oil.
I figure if I am removing the old distributor I should at the same time go electronic ignition.
I was looking online at MSD systems but there are a few different models offered.
From experience what would be recommended?
Thanks for any and all inputs.
Oil "in" the dizzy or just just around the entry port in the intake/block..?
Entry port would be an "O" ring leak. (or intake leak)
Oil inside the dizzy would be to much vac. ported to the vac. advance.
There's a mod kit out there, that just req. taking out the points & install the electronic set-up.
Seems it was around $60
But yah., MSD is good....haven't heard any neg. about any of them.
Check out Summitracing.com for some good research.
FWIW., I built my own for $30 .... :eek: /emoticons/[email protected] 2x" width="20" height="20" /> B)
dewshan
amarillo tx
I have a 69 Bronco with a stock 302. Distributor is the old point style & is leaking oil. I figure if I am removing the old distributor I should at the same time go electronic ignition.
I have had good luck with the pertronix HEI billet distributor. I think they have one now that also has multi-spark as well? It may not work with the stock hood though. pertronix website street version with vac advance.
BronBronBronco
Santa Clarita,CA
Oil "in" the dizzy or just just around the entry port in the intake/block..?Entry port would be an "O" ring leak. (or intake leak)
Oil is collecting on the outside on the intake. I will remove the dist. and replace the o ring.
I will try to find the conversion kit and do the mod if there is not a big advantage of replacing the complete ignition.
Bully Bob. Any suggestions were to buy the mod kit? I will check Summit Racing as they do have a ton of stuff.
Thanks! :) /emoticons/[email protected] 2x" width="20" height="20" />
figjeti
