replacing my distributor
thesearemyshoes
New York
I'm replacing the distributor in my 79 bronco. I have a 351 windsor and I'm pretty sure the timing is off. I cranked the engine so that the rotor pointed to the no. 1 mark on the distributor cap and took the distributor retention ***** off but the distributor still wont lift out. Any tips or ideas how I could tell if the no. 1 piston is all the way up?
Rons beast
Hey shoes,
With the distributer rotor pointing at #1 the timing mark should be visible. Turning the crank to have the mark at TDC will put the #1 piston at TDC of the compression stroke.  Pulling the spark plug and shinning  a light should enable you to see the piston. If space doesn't allow that , a soda straw can be inserted in the plug hole and you should be able to feel the piston.
A stuck dist. can be freed with some WD-40 at the base, and twisting back and forth, while pulling up.
You didn't explain why you feel the timing is off.  If TDC does not make the  #1 piston at the top of it's stroke , you have a problem with a timing chain and/or gear, or the outer ring of your balancer has slipped.
Good Luck
As Ron advised and,
I would add the question;
By what means did you determine the dizzy was bad & needs replacing..? What are your symptoms.?
It would be a shame to buy a new one & still have the same problems.
If the timing mark is on "O" or "TDC" & the piston is at the top of its stroke, & the rotor points to #1.., you may need to have the module tested.
The module is more likely to have issues than the dizzy.., with the exception of the pick-up coil in the dizzy.
The pick-up coil is not expensive.
thesearemyshoes
thesearemyshoes
New York
when you say TDC, what are you referring to? Sorry if that's an amateur question, but I'm still pretty new to working on vehicles
Rons beast
TDC= top dead center....the zenith of a piston's stroke.  An engine is built with the timing mark on the crank balancer to be at 0 degrees, (or TDC), when the #1 piston is at it's absolute top of it's stroke.
NOTE!   the piston is at TDC 2 times in a 4 stroke engine. A compression stroke and an exhaust stroke. The compression stroke is when the distributor should have the rotor pointing at the #1 plug terminal.   If the rotor is pointing 180 degrees away from the #1 plug terminal the piston is on the exhaust stroke.
Gary wilder
