Relocating Steering Box
nitro520
I have a 77 f-150 2wd that I need to move the steering box or do something different with because I need more room to bring the headers thru the inner fenderwall area. Right now it is set up with a power steering setup.
Great site here with a lot of info, thought someone might have a idea. Thanks
BigNasty
SquirrelBait
NC
What brand of headers is that?
I have an 82 351w withe what I consider to be not so block hugging and I have plenty of room for the headers and the steering box.
If you got the headers used, it is a whoops kinda since they don't seem to me to be the proper set for the truck.
If new, I would take them back pretty quickly for an exchange or a refund.
I was about to click submit and wondered.. is the engine a big block?
N
nitro520
Ya, its a 520" big block. I need to be able to run a 2 1/8" primary. That is a little hard because of steering box. If I stay in frame it is to tight of turn, if I go outside of frame I need more room also. :( /emoticons/[email protected] 2x" width="20" height="20" />
BigNasty
SquirrelBait
NC
EEEK!
Got pics?
And you may need to scrap that idea and have the headers custom made for it..
Know any good welder/fabricators with a tube bender?
Might have to run the tubes around the steering shaft for mock-up, then pull the steering shaft for the header installation and put it back in through the headers.
Other than that, all I can think of is either some straight pipes, upturned like a top fuelie and hoodless :) /emoticons/[email protected] 2x" width="20" height="20" />
Or just send the engine to me so I can build the Yugo sleeper I have always dreamed of :D /emoticons/[email protected] 2x" width="20" height="20" />
N
nitro520
I have a guy to fabricate the headers, but cylinder number six has no room for what I need to do.
I like the upturned straight pipes idea, but don't think they will like that at the dragstrip. :D /emoticons/[email protected] 2x" width="20" height="20" />
BigNasty
SquirrelBait
NC
Hmmm..
Heim joints, tube bracing and u-joints come to mind for relocating the steering shaft around the headers.
It would be an all custom shaft most likely, possibly done by your weld-up guy, but seems to be the easiest idea I have other than the upturned headers and should keep it legal and safe for the street.
You might want to check on some hot rod forums for ideas on how to get or make the shaft properly.
One I am on that seems to have a lot of knowledge is Classic Car Forums
N
nitro520
Thnx, I will check out the site. The more I think about it the more i think you are right about heim joints and relocation. I was hoping to find a smaller box, but probably wouldn't be heavy enough.
indoz
These are the extractors in my F100, 460 BBF, keep in mind this is right hand drive Good luck.
Henk from Oz
indoz
Oh and by the way the steering box is still standard and the pipes are 2"
N
nitro520
Great thanx for the pixs. Looks a little tight, but I know it can be done now.
N
nitro520
Indoz, what year is your f-100. My steering box sits alot closer to the firewall. The shaft between the box and firewall is not much longer than the rag joint. Mike
fred tyler
