rear shock mount broke
paintitblack
i own a 88 ranger and the rear driver side shock mount frame side broke and im wonderin if the fullsize bronco ones will fit the ranger mounts if anyone could help thanxs or help me find a new one
If the stud broke at the top mount then you can drill it out I had that happen to my Bronco2 and used the stud rancho gives with the steering stabilizer shocks you could also use a regular bolt and it would work just fine :D /emoticons/[email protected] 2x" width="20" height="20" />
andre
gatineau hill quebec
need one from rager or bronco II
parts name is "rear shock bracket "
yes still can get them
local dealer or body shop
kyleh01
