raw fuel
hughd
am thinking about increasing my spark plug gap on my 289. what would that do with an unburnt fuel smell?
Rons beast
Hey hughd,
Welcome.
I assume that you're working on a 67 with carbed  289 .........Best thing is to adjust the carb for the correct mixture.  It's difficult to answer about the plug gap, as we don't know if you are running stock 67 points ignition, or something upgraded that could handle bigger gaps.   It isn't a good idea to try something to mask a problem.
BTW if you  go to settings and fill in your signature with the info on your truck it will help get better advice.
Couldn't agree more with Ron.
Bad carb/mixture or faulty timing can stink up your garage, clothes, nose-hairs, etc. to the point
where only a shower will cure you..!
And for sure, the info. pages filled in will get you valid help.
Larger gap may even make it worse.
H
hughd
hey, new guy here. am running edelbrock jr intake with holley 600 carb. headers with mallory unilite ignition. jetted to leanest jets i can get with autolite 45 spark plugs
Mallory recommends a certain coil., a ballast resistor, & an active power filter.
(do you know if you have those..?) (Is this dizzy in good shape..?)
This being an electronic/pointless ignition, it's likely the plug gap should be wider.
They come in mechanical & vacuum advance. Yours is...??
However, the ignition isn't much help if the timing chain is shot., or the timing is
just way off.
(More info = better answers... :D/  )
You see the info to the left & below my post...?  It all helps.
I would suggest you contact Mallory for your set-up info & plug gap.
Summit Racing can help also, as they sell Mallory.
Let us know what you find..., It could help others.
Rons beast
hughd,
 Remember the jets are only part of the fuel circuit The mixture screws and off idle circuit contribute to the total fuel delivery.  If  the timing is off the vacuum can be low and contribute to excess fuel flow
Bully gave good tips and advice, and remember to let all know what the results are.
Good Luck
H
hughd
i have a master blaster coil and a ballast resistor.do not know what an active power filter is. timing is good. do not know conditiion of chain. has 61000 original miles on it. by the way, how do i put a picture of the truck on this site?
The filter prevents power spikes as I've heard it.
Test timing chain ; "KEY OFF"  move crank by hand back-n-forth ..., note slop by watching the rotor.
Should be pretty much in sinc.
Clean rig.., assume you just got it....
H
hughd
had it for four years now. sorry about the delay been busy. am in contact with mallory. will let you know. thanks
fred tyler
