Power Steering
Jayson5150
Buckeye, AZ
What vehicles can the power steering pump, brackets and box can be scavenged to fit the early bronco? I know(assume) to find the same engine size. But would an F-100/150 bolt in? or are there modifications to be made?
S_bolt19
Colorado
The answer to your question depends on what year EB you have and weather or not you have an I6 or V8. If you have a 66-75 (with a V8) the the 73-75 PS unit will bolt directly in with a little inner fender, inner grill & radiator modification if it is a pre 72 1/2 vehicle. If you have the 72 1/2 through 75 EB then it will bolt directly in w/out any cutting mods. If you have a 76 or 77 then you need a 76-77 PS system. The reason for this is the 76-77 used a different steering linkage than 66-75. That is the easiest PS mod out there, no matter what anyone else says. It is a direct bolt in application. The truck box is a little more difficult, but less expensive because most of the EB PS systems have been robbed already, but you can find them. I don't know how to adapt it for the inline 6 engine.
J
Jayson5150
Buckeye, AZ
Thanks S Bolt... I have a 69 with the 302....I'll check the yards & see what I can find....or go with the truck mod.
