power steering box
bartowb
Cheyenne Wyoming
need some help. have a leak in my pressure side hose on my power steering. i have tried to find a replacement hose for it that works with my stock ford pump and all that i have found are not the correct one. i am not sure if i have a aftermarket pressure hose or if ford gave me a bastard set up. either way i can't find a hose to fix it. my next option is to put a different pump on it such as the saginaw pump and get a new hose set up. which comes to my question. Is there a way to determine what steering box i have? ford or saginaw. the pumps i have found require you specify what box you have to ensure the right fittings. any help would be appreciated.
thanks
bartow
eholt80
