Posi
4xfan78
Georgia, augusta
Very bad idea, it will not last long and you will need to replace the entire rearend after it blows up. But if you really want to do that you weld the spider gears. A minny spool would be a better way to go, chech summit or jegs.
:-& If all you want to do is drive in a strait line, go ahead and weld and while you're at it weld the steering knuckles so you don't get tempted to turn :lol: , but e prepared to pick up the pieces when you snap an axle or tear up a tire. Better yet, buy a carrier with posi in it and replace the one you have. Check out Jeff's Bronco Graveyard or LMC Truck.
f250rangerexplorer
Nor Cal
i'd spool the rear. it's fairly cheap. i wuoldn't recomend welding them together either.
Oh yeah POSI is a GM term not a FoMoCo term. Ford called it Limited Slip. :)>-
4xfan78
Georgia, augusta
If you want to get real picky it's actually called a "trac-lock" but who cares whatever you call it it still makes both tires turn when you need it.
If you want to get REAL picky, :D /emoticons/[email protected] 2x" width="20" height="20" /> Posi is the generic term applied to the types rear ends that do some sort of locking, the other terms describe the method of locking. :rolleyes:
fred tyler
