Painting My Cap
FLYFSHIN
Marquette, Michigan
My 95 bronc is metallic green. The color of the top has faded to a girly teal. I want to paint it black. Do I need any sort of special paint? Does it need a flex agent in it, and should I prime it first?
Also, there is some wax from the previous owner that's on the edges, I'd like to see it gone before I spray a color down..any tricks to removing that stuff?
There's a bit of rust starting around the top of the rear quarter. In your guys' experience, would I be better having a shop grind it off, prime and paint, or buy new rear quarters? I'd hate to have it fixed just to see it resurface next year. The michigan winters really tear up a body...
hoggjaw
ohio
paintig the top is sumthin i heard aint an ez thing to do. lot a people said to leave it alone but i wood call a body shop. you should see my rear quarters, bondo dont rust! i bought the scab panels and welded em in and it looks great, but mud dont care bout that.
I have seen some folks use regular rattle-can spray paint to "freshen-up" their hardtop. It only lasts about a year or two, though. Since it is fiberglass, the proper way is to gelcoat it, and the rough texture makes it difficult. If you have the money, have the top sanded smooth and then gelcoated.
When it comes to removing wax, an ammonia-based cleaner like Windex works the best.
As for the rear quarters and other body panels, if you catch the rust before it eats a hole thru the metal, it can be repaired with sanding and painting. Remember that bondo is no good for patching holes, since it won't hold to air. It will just crack and fall out within a few months.
F
FLYFSHIN
Marquette, Michigan
Nope, no bondo will be used in my ride. Does a regular spray can come out ok? It fades after a year or two though?
The regular rattle can spray paint looks fine, even shiny, if you take your time. It will peel, flake, fade, all of the above after a while, so you will have to do it again.
fred tyler
