OOPS!!!
I check those bolts several times a year. I found mine loose once bu not quite that bad. If the threads are still good, you should be able to just tighten them up.
89Bronco58
Jersey
haha damn, that same shit happend to me, just tighten em up, you will be ok
bidibronco
Norfolk Va
Does anyone know why this does this? I've had the truck for about a year and a half and since I've had it I've never taken it out in the mud. I don't have all the bugs worked out of the transmission and the new bushings I need to put in the front TTB. I plan on dropping the whole driveshaft and putting new u-joints in it. Anyone know what else I should do why it's out or anything I should check? Thanks everyone! :-"
rubberdust
Henderson NV
wow that's something I haven't had fall off. I have had the u joints go away & cause quite a vibration but never loosen the bolts like that. I'll be checking mine in the morning
Broncoholics
Broncoholics
Washington State
Thats will definately clear up the vibration problem! Better put the bolts back in with blue loc-tite. Red might be needed but takes heat sometimes to break the bolts loose.
Better look around for other loose bolts...
eholt80
