Newbie Question....
OutCole'd
Vegas
I'm looking at a 77' Bronco with Manual brakes, I haven't driven it yet, just bs'ing with the guy so far.
It has manual brakes do they work with a crap? Would I need to do the power booster conversion as soon as I buy it? What do you think?
Thanks.
Hi OC..,
I'm 18 yrs. with my manual brakes....still "stop on a dime"..!
Like anything else ..Brake system is only as good as its up keep.
As I've said B4., Ford didn't make these rigs so as NOT to stop..!!
Lyle
Lakewood Colorado
The 77 EB I built before the one I am working on now had factory manual disc brakes. They were excellent and truly did stop on a dime. I never had any problem stopping at any time. That bronco was the finest bronco I had ever built or driven. I always thought I would convert it to power brakes one day, but never really saw much point in it. The 77 I am working on now has factory power brakes and they work fine as well. Not real sure the expense would be worth the reward for a conversion epecially on a 77 with front disc brakes. An earlier EB without discs there is no question, power conversion (and disc conversion) would be a must. My broncos typically run with a tire not much over a 10.50-15, so maybe larger tires/wheels would dictate a conversion for you as well.
'Lyle' said.,
The 77 EB I built before the one I am working on now had factory manual disc brakes....................................
Again..,
with 50+ points of interest...!! Where's the pics..!!! > ^_^ /emoticons/[email protected] 2x" width="20" height="20" />
O
OutCole'd
Vegas
Ok, Thanks for posting, that's all good news. Hopefully I will pull off the deal, and I can post some pictures then.
S_bolt19
Colorado
Power & disc brakes is a personal preference. I know Bully Bob loves his originals and he gets them to work wonderfully. Me, on the otherhand, I prefer the power/disc setups. If you are using a tire from stock height up to 31 inches in height, I would say you are going to be fine. Anything above that 31" threshold, I would say at a minimum, do front disc brakes. Simply put, bigger treads = harder to stop. I run power & disc on all 4 corners and absolutely love it. The problem with power is that it takes up a lot of space in the engine compartment and/or requires power steering (hydroboost). But the simple answer is, if you are running smaller than 31" tires, leave it stock, larger, at least do front discs.
Lyle
Lakewood Colorado
'Lyle' said.,The 77 EB I built before the one I am working on now had factory manual disc brakes....................................
Again..,
Bob, I will get pics of my 77 soon. Thanks for the interest. It is a beautiful little bronco.
BTW my 77 has silicon wiper blades.
O
OutCole'd
Vegas
OK, next question. The truck has a three speed, on the column. One chore I'm going to want from this is to launch & retrieve my 28' 5k lb boat and put it back in storage. I know it will have the power & weight, just worried, am I going to burn up clutches towing like this?
No wonder ya want "brakes" ...!!!
Depends on how far & the terrain....where are you..??
Taking that train up on a freeway would be signing your death warrant.
Clutch would prob. be OK...., it's "jack-knife" potential I would consider.
Short dist. on side-roads should be fine.
O
OutCole'd
Vegas
No wonder ya want "brakes" ...!!!Depends on how far & the terrain....where are you..??
Never on a highway, or even a major street, Just about a 1/2 mile from my storage unit to the launch ramp. Flat smooth roads, easy drive. A 2WD P/U will do it now no problem. I've just never towed with a manual and the storage unit can be a tight fit.
The Bronco would stay with the boat in Lake Havasu AZ. Watch for me on Party Heat...... :D /emoticons/[email protected] 2x" width="20" height="20" />
Put a hitch/ball on the nose...makes for easy shed parking.
As for pulling boat out of water/up the ramp.. might want to practice (starting uphill fr. a dead stop) with just the trailer...you'll need to "load" the clutch a bit B/4 releasing the E-brake.
I've seen a few veh. become submarines.... :eek: /emoticons/[email protected] 2x" width="20" height="20" />
Have fun..!
Sandoval_broncosauria
