my 79 died today, any help?
shortbusrider41
luckily i was a block from my house, when my bronco just died on me. she still has power, and will crank pretty strong when i try to start it, just won't turn over. it has gas. any advice would be AWESOME. thanks all!
Runnin'OnEmpty
If not the igniton module, then check the pick-up coil inside the distributor.
No-fire conditions are usually caused by either of these two causes.....
ford/moparguy
Check your ecm electronic control module. had one go out before. had full power everything wouldnot start in Hawaii. had it towed as didn't know problem found out the ecm went bad.
Hope this helps Lee
check your ecm electronic control module. I had one go out on me in Hawaii. I didn't know what was wrong so I had my truck towed to a shop. I had full power everything but no start.
Hope this helps Lee
Sandoval_broncosauria
