MTS replacement main fuel tank
routerman
I am wondering if anyone has used the replacement poly tank from MTS in their 71' Bronco? If so, have you had any leak problems?
73dreambronco
Make sure the gas is not coming out of the vent hole, if you go up an incline and the tank is full the vent will leak. did you use the sending unit o-ring?
hope this helps
R
routerman
Make sure the gas is not coming out of the vent hole, if you go up an incline and the tank is full the vent will leak. did you use the sending unit o-ring?hope this helps
Thanks for the reply. It was the sending unit o-ring that slipped out from under the sending unit. Mike at MTS fixed me up. I sent the tank back to them and they ended up sending me a different one. I am going to install it tonight.
eholt80
