msd ignition on a 77 bronco with 302
OJ_Bronco
Cocoa Beach, Fl
on my bronco the motor will turnover but wont fire
but there is no spark coming form the distributor so i bought a new distributor cap and that still didnt work
What ignition system do you have? Put your truck vitals in your signature file, it will help get better answers.
O
OJ_Bronco
Cocoa Beach, Fl
the problem was that the ignition box had burnt out
so i got a new one and it started up a couple of times
and now it wont start when turn the key it makes this noise like somthing is hitting somthing else and the motor wont even turn over
i have the 6al msd box with the distributor and rotor and have the coil
I'm assuming that by won't turn over that you mean the starter is not engaging or working at all.
If your starter isn't turning the engine over it's not going to start. So the first thing you need to do is solve that problem. It could be starter, solenoid, bad cables from the battery to the starter or a bad ground cable from the battery to the engine block. is the battery fully charged, use a multimeter to check the voltage between the lugs, if that is OK, check for a voltage reading
When checking cables look at the condition of the cable where it attaches to the lug. Clean all contact points and re-connect them. Then try starting the engine. If the starter still does not turn the engine over you will need to do a little more specific troubleshooting, like checking the starter, start solenoid, etc.
fred tyler
