Loose Hub Cap
walkdawg
Jacksonville North Carolina
This kind of goes with my other problem. I noticed that not only does my 4 hi jump out but my right side hub unlocks. I **** a look at it and the only problem i see is that it is a little loose and it stays locked until it hits a bump. I tryed to tighting it but the bolts will not tighten any tighter. The other side dont move at all but the right side moves alittle i tighted it alittle but it still moves should I replace the cap?? Thanks All :unsure: :unsure:
You shouldb e able to get a maintenance kit from your parts dealer which includes new O-ring seals and I believe screws. I'm pretty sure I gor new screws wit the one I baught a couple of years ago.
Good Luck, :)>-
fred tyler
