lift hieght
BENWA3004
can someone help me and tell me what or where to measure on my 79 Bronco to give me a measurement on my lift height? i need to replace some parts and it is an old lift and i dont want to change the ride hieght.
thanks for the help
Look at the front radius arm drops if its the kind that were a spacer between the factory mount and the frame measure between the bolts that hold the spacer on the frame and the factory bracket center to center straight down and that will be your lift height theres other factors too but will give you an idea . :D /emoticons/[email protected] 2x" width="20" height="20" />
figjeti
