level
bigblue35
my ford bronco sits alot higher in the rear that the front. What can i do to level the front to the back?
JLasvegas
check bronco grave yard . com, they sell a leveling kit.
im assuming that the suspension is stock, correct?
BB33's
Rancho Cucamonga CA
If your truck has rear blocks you can just go with a 1 inch shorter block and that will do a nice job of leveling it out.
bigblue35
But i want to level the front with the back. so i need to raise the front some.
BB33's
Rancho Cucamonga CA
Yes and no if the rear has blocks the cheapest and easiest thing to do would be to put in a i inch shorter block. They do make leveling pucks for the front that go on top of the front spring but your brackets aren't going to accomodate for the the extra height and your alignment will be off.
What set-up do you have in back? stock leafs and blocks, AAL's, or new springs? the easiest way to adjust the"rake" of the rig is by adjusting the rear suspension. A shorter block or removing one or two leafs from the spring pack. If you have a 6' lift kit with front coil springs, any height adjustment there will ruin your alignment.
bigblue35
stock leafs with a block.
kyleh01
