Ignition help
86_Beast
Sapulpa, OK
So I went to check the timing on my bronco the other day, and couldn't find the timing mark when I plugged the timing light on cylinder 1 spark plug wire, so I played around moving it from wire to wire and found it on spark plug wire 4, What the heck happened to cause this? Also, it takes FOREVER to start my bronco hot or cold, it just cranks and cranks until it finally fires, Any Help???
Thanks,
Ken
I doubt that being that far out of time that it would ever start, much less run. Are you sure you are on plug 4 and not #1? #1 is the front passxen ger side plug.
