i need some help please
grmlin72
i put power to coil i here fuel pump go on but i replaced the relay switch and still nothing i need some help i also replaced mod and computer no burnt links also checked the inerta switch under passenger side hit reset swich and nothing why i would not be getting power to the coil or here the pump go on i just rebuilt the heads also and the transmission had that checked and it was fine so i need help getting power to the coil i turn the key and nothing happens please help its my only transpertation and im desperate
Have you used a meter to see if you have 12V to the pick post on the start relay when the key is in the start position? ( the one going to the small post) If not, then you have it licked, just follow it back to the key. On most standard shift vehicles, you need to have the clutch depressed to start it, I;m not sure that is true of an EB. An automatic goes back through the neutral safety switch on the transmission.
FordBroncoII
Bridgeport, CT
I am not sure that I read your comments correctly, Is the starter relay working/clicking when you turn the key? When I had a similar problem with a new coil installed, it turned out to be a corroded battery terminal connector/positive terminal from the overcharging voltage regulator.
kyleh01
