Horn
Buckin75bronco
Montana native currently living in Missouri
I need to fix the horn on my 75 bronco. It is a state requirement for licensig.
Not sure where I am going wrong, but i could not get the old horn to work and now that I have bought a new horn for rplacement I cannot get it to work either.
Help anyone.
Hi Buckin, welcome...,
'K bar S' was a good EB sales & serv. company in it's time....some of the mods you have may be out-dated..., but not all. (more on that later)
As to your horn.., you may have to pull the str. wheel to see if the wiring & "rub" connector are still functioning. The wires come out of the column just below the dash...you might look there as well. Not sure if some yrs. came with a horn relay...if there is one, it could be stuck.
BUT 1st.., test both the old & new horn by grounding it & touch a hot wire to the plug.
AND.., test the hot lead on the veh. with a voltmeter while someone pushes the horn button.
fred tyler
