Hi wil..,This always makes me wonder.... :huh:
I see you got the shroud back in.., that's a good thing but other questions come to mind.
Did you chem. & flow flush the whole sys. pryor to new radiator..?
YES, NICE AND CLEAR USED 90 ANTIFREEZE.
What rated thermostat did you use., & is it (good brand) new., or tested...?
DONT USE A THERMOSTAT HERE IN CALIF.
What are you guaging temp by....stock dash ga. or after market.?
USING AUTO METER GAUGE. SINCE I PUT IT IN YEARS AGO (AND BEFORE HEADERS AND NEW RAD) IT ALWAYS RAN A MAX OF 190 DEG
------in other words ..is this an acurate reading..?
Is there any action going on fr. rad. to overflow bottle..?
FUNNY YOU SOULD MENTION THAT. IT NEVER DID IT BEFORE BUT SINCE I PUT THE NEW RADIATOR IN. ONCE IT GETS UP TO TEMP IT BUBBLES INTO THE OVERFLOW TANK A LITTLE SO I THOUGHT I HAD TO LOW OF A PRESSURE CAP...13LB. I TOOK IT OUT FOR A LONG DRIVE AND WHEN I CAME BACK THE OVERFLOW TANK WAS UP TO THE TOP.
"...and it always ran cool until now." YES
Cool, I would think would be @ 180
YES, BETWEEN 180 AND 190 DEG
I PUT PUT A NEW CARB ON IT AND TOOK THE MANIFOLD OFF AND CLEANED IT UP AND PUT ON NEW GASKETS. TORQ TO SPECS. NO WATER IN OIL OR EXHAUST BUT I THOUGHT THERE WAS IN THE EXHAUST. WHEN I FIRST START IT UP LIKE THE NEXT DAY I SEE SMOKE/VAPOR COMING OUT OF ONE SIDE EXHAUST FOR A COUPLE OF MINUTES BUT I SMELLED AND TASTED THE EXHAUST AND IT DIDT SEEM LIKE ANTIFREEZ. I PUT A PRESSURE TESTER ON THE RADIATOR AND TOOK IT TO 15 LBS AND NOTHING.....STAYED ROCK SOLID.
Hood venting may help....wrapping the headers may help....but I would want to be sure I'm starting with an accurate temp. reading.
Is everything tuned correctly.?
I HAVE ALWAY WANTED TO VENT THE HOOD SINCE I GET TONS OF HEAT IN THE CAB DURING LONG TRIPS...EVEN BEFORE ANY HEADERS ETC.....BEEN THAT WAY FOR OVER 15 YRS.
Not a big fan of cutt'n holes in the hood......but most EB houses have hood scoops/vents. ( www.ramairhood.com )
Up dating your sig. page would help....
HTH
