holley trk advenger
ALLENP7
can someone please tell me what spring size is need to get the secondary to open at 2500 motor size302 not sure if built but seems to have alot of pep carb is holley trk advenger
Crude dude
Phoenix, AZ
When the secondaries open at 4000, can you feel it? It seems that the secondaries would be open much sooner than that unless you have some vacuum issues with the motor. Does it idle smooth? Big camshaft? I would call Holley with that question.
LtDan
The silver spring will allow the secondaries to open sooner (for light trucks) and increase performance.
The black spring (installed at the factory) will force the secondaries to open later (for heavier trucks) and increase fuel economy.
For tuning check this out: (page 12)
http://static.summitracing.com/global/imag...199r10268-4.pdf
Why do you want them to open at 2500 RPM? Unless you are racing and spend most of your time at wide open throttle, that is too close to normal cruise RPM. They should only start to open as the demand starts to exceed the primary's ability to supply air. I'd suggest you get a book on whatever carb you are using and read up on the subject. If it is a Holley you can easily find that at a book store or local library.
Here is a link that may help you http://www.bob2000.com/carb.htm
Leadsled
Bullhead City AZ(right on the river!!)
I second this. If your looking to burn a lot of fuel then you should look at getting the same carb with a mechanical secondary.
