Help!
mel
been haveing problems with my 95 cant pin it down engine runs fine sometimes for days outher times only for minites ill be driving and the engine starts to cut out and dies alltogether no spark at coil wait 5-10min and it fires any suggestions. thanks mel.
I would suspect the ignition module is going bad. You might try pulling the engine codes, and see if it's an ignition problem; or if your fuel pump is starting to fail it will cause similar symptoms.
Raven
between ignition modual and possably a new coil ...
M
mel
hey thanks guys! put a new pump in last week and pulled codes not showing faults going to replace coil next. any other ideas thanks mel :) /emoticons/[email protected] 2x" width="20" height="20" />
M
mel
not sure highboy ? zero spark at coil
M
mel
fixed it it was-----------------------------------------------------------------------------------------------------------------------the f-n coil methed of diagnosis was tapping ******* the coil with engine running and it died then smacked it agian and it fired repeated 5 or 6 times thanks for the input mel :D /emoticons/[email protected] 2x" width="20" height="20" /> p.s great site
stevedave
