HELP! need gear info
TheStig
I have a 92 Bronco 5.8
It has 35's on it and the gears just got chewed.
What is the stock gear ratio?
What should gears should I run if I want more torque but can still get up to highway speeds?Picture_075.jpg
Roadkill
Killeen, TX
Your truck most likely came with 3.55 rear and 3.54 front. Most people with 35" tires who change gears go with either 4.10 or 4.56. (it seems to me that the majority lean a little more toward 4.56) There is quite a bit of information available on the subject. I can't post a link to anything at the moment since I'm on a public computer right now, and I don't have access to all my saved links. But if you search a little you will find what your looking for.
One thing to keep in mind, is that you will need to re-gear both the front and back in order to continue safely using 4x4. (not trying to insult your inteligence if you already know that, some people don't) Also, your Dana 44 front diff will require a new carrier with the 4.10 or lower (higher number) gears.
What should gears should I run if I want more torque but can still get up to highway speeds?View attachment 5274
As Roadkill already mentioned you'll be wanting 4.10's or 4.56's w/those 35's. If you're looking for torque I'd run the 4.10's instead, the 4.56's will get you up to speed a little faster but you'll sacrafice some torque for speed, there's always a trade off.
Coastersfwb
