Help in Dallas
Dagger_91Beast
Dallas, Texas
I need to find a good mechanic in Dallas, preferably near Lewisville/Flower Mound. I like working on the beast, but I'm on the road so often that when I get home I just want to DRIVE her. Currently I have an issue where the battery runs down anytime I leave the truck. Originally it was running well, then came back into town and nothing worked. Checked the battery - dead. I trickled the battery back up, plugged it in - dead. I put in a new battery, it worked fine for about 3 days, got back from a trip last night...dead. I'm sure it's something simle that I could fix with time, but I'd like to find someone here I can trust for the things that I just don't have time to mess with.
If anyone has had good luck with someone from around here I would greatley appreciate your recomendations.
Thanks,
mbtech2003
cape cod, mass
get an amp meter and install it between the neg. side of the battery and the cable. then just pull each fuse one at a time and check the amp meter for any change. there should only be a max draw of .050 amps. first thing i would check is to see if any interrior lights are staying on ie. glove box... sounds like there is a 1-3 amp draw in your truck.
