Half Cab
newguy
After seeing Ted Nedgent's Half Cab Bronco I'm thinking of going that route. Has anyone used the fiberglass half cab kit? What about the roll bar? Does the standard standard bar still work? If I have 3 point seat belts would I need an inside roll bar?
Thanks for the advice.
Broncoholics
Broncoholics
Washington State
I run a fiberglass half cab and love it. Its light and easy to fit when I hit trees and rocks. I built my rollcage with the top on and drilled holes thru the half cab. It wasn't easy (had to use mirrors and bend the welding rods) to do with the tight space.
There are a few that make half cab roll cages that are real nice. Or you can go with a standard rear 4 point can be done with it. This type doesn't protect the windshield area in a roll over (most of weight is there) so a good cage is worth while. I'm on the wrong computer now and will send some photos soon.
eholt80
