MachDream
MachDream
This one concerns my IVR and gauges not working. The other day the temp, gas, and oil pressure gauges went down to zero (quit working) The volt gauge kinda bounces there right in the middle like usual, but am i correct in thinking the volt gauge is supplied with the full 12 volts where the other gauges come off the IVR reduced to 6v? with the key on, test light in hand, if i touch the the one side of ivr it lights up bright, if i touch the other nothin but if i touch the little threaded adjuster thingy on the IVR that lights up bright too? is that voltage adjuster ***** supposed to light up if touched? is it supposed to be bare metal or have a plastic sleeve over it? (mine has no protective sleeve) I guess what i expected is with the key on, i would test the one side and it would be bright (full 12v) then when i touch the other side, not as bright (reduced volts). Please correct any wrong thinking i may have on this and offer any suggestions/remedies you may have. I will go to aftermarket 12v/ground gauge set if i need to but would like to run my stock gauges if possible. IVR's ive seen go from $30 up to$50. Thanks!
