gas pick up from main tank
bingen
Cebu, Philippines
has anyone had this problem, once the fuel line is connected to the rear main tank, fuel won't flow consistently to the pump/carb. Blow into the tank and air flows...
What do you think is wrong?...
Haven't pulled out the float/pickup unit yet.
Also using plastic fuel line.
Any ideas
Thanks for any info/suggestions
"Blow into the tank and air flows..."
This is pretty vague...
"once the fuel line is connected to the rear main tank"
Where exactly are you making this disconnect/connect..?
You should do it fr. the inlet hose leading up to the fuel pump.
Should be able to blow air easily (by mouth) all the way back, & bubble in tank.
Also.., if you can blow air back thru the fuel pump, (fr. the outlet side) the pump is weak.
{Faulty check valve(s)}
HOWEVER.., the screen could still be in place on the fuel pick-up (inside tank)...& mostly plugged.., creating a restriction but still allowing air-flow.
"Also using plastic fuel line."
This is fine if you mean the original factory line.
