fuse
hollis
got a question have a 1990 bronco auto with the 5.8 just bought it and by the battery there is a inline fuse in one of the four wires right before the cylanoide i dont know if it is suposed to be there looks like added or redone anyway keeps poping the fuse anyway if it suposed to be there and redone what size fuse it has a 15amp in it right now think maybe it is to small if anyone knowes please let me know
Redneck86
First On Race Day
Colorado
well if it was added on there by a PO id just take it off and splice the wires back and be done with it, if its factory it must be there for a reason, so lookin the owners manual and it should say what fuse it needs if its factory. If it is a 15 amp fuse and it keeps blowin you probably have a short some where.
Sounds like someone may have added it . Trace the line to see what it powers. There may be a short that is causing the problem :glare: .
BroncoJoe19
I am pretty sure that there is supposed to be a fusible link in that circuit. My guess is that the PO did a half baked repair and put an inline fuse there. That would be a no-no. I'm sure someone who is familiar with the actual circuit will give you a better response. Otherwise we'll have to do a search on fusible links.
joe
H
hollis
well i trace it back to the ignition it stays hot at all times and when it pops the truck dies and wont start dont have a manual and the hanes book dont show or tell just says on the wiring digram that is a inline fuse and hot at all times just hoping one of you guys had a fuse in yours and could tell me the size that way i could narrow it down thanks
H
hollis
i put another fuse link on in because when i didnt know what was the matter with the truck because it wouldnt start i went an cleaned the termanils and when i put back nothing and i was looking at the wires and i hit that fuse and i could hear my fuel pump cause if left the keys on so i figured it was lose connection and the fuse does not always pop but it has twice in 2 weeks
BroncoJoe19
Description: The traditional fusible link is a short section of wire that has a smaller diameter than the rest of the circuit. When current flow in the circuit exceeds that of the fusible link, the wire melts and interrupts the circuit. This type of fusible link is becoming quickly obsolete, as many carmakers have opted for newer technologies such as the cartridge style fuse element or **** fuse. When a fuse link
BroncoJoe19
It appears that you should have a red cable going from the battery to the starter relay that is mounted on the fender/wheel well. from that terminal there are four wires probably all yellow. The first yellow splits into four fusible links
18 ga brown to yel to ignition switch
20 ga bkue to yellow to rear defogger
18 ga brown to blk-orange to fuse #14
20 ga blue to yellow to trailer lights relay
the second yellow wire splits
into three fuseable links all of them are 20 ga blue
they go to
1. yellow fuel pump relay
2. yellow EEC Power relay
3. Red Trailer elcetric brake control
the third yellow
1. yellow to engine compartment light and fuse #1
The forth wire (I guess it is yellow)
is a 14 ga green fusible link that goes to the alternator
I hope that helps.
joe
