fuel tank
bartowb
Cheyenne Wyoming
i was wondering if the oversized main tank 23-24 gallon are direct replacement for the stock 13 main tank or am i going to have to mod to make it work? any help would be appreciated.
Broncoholics
Broncoholics
Washington State
If you want a larger tank, go with the one Wildhorses sells for body lifted Broncos. You don't need a body lift to run this tank its just a nice option if you want to raise it to help protect it later. Plus you don't need spacers if you do run a body lift, rests on the bottom of the body.
I raised my stock tank to the bottom of the body utilizing my 2" body lift.
bartowb
Cheyenne Wyoming
i will give the WH tank a look at. hadn't really looked around yet just heard that there were bigger tanks out there. thanks for the help
Bandit
BANDIT
Afton,Wyoming
I love Wild Horses for most anything,but for the tank I like the B.C. broncos 24 gallon,it has an adjustable strap system that lets you reajust it for any body lift.If you read the Wild Horses info,it has one tank for lifted broncos,and one for non lifted,and one is a few gallons short of the other.
BANDIT <)
