fuel headache
DASBRONCO
BAYAMON, PUERTO RICO
Hi guys, im here again with my bronco making me pull my hairs. my 79 bronco cant seem to deliver fuel to the carb, it stalled when running on the highway, i opened the hood and the fuel filter empty. when she felt like starting i would get home. first thing i replaced was the fuel pump for a carter unit, it didnt work. next i relaced the carb's float-seat-valve in the bowl, id didnt work either. i went crazy and bought a sending unit and dropped the gas tank, and flushed the fuel lines. i found the tank was really clean so i had it flushed and put the sending unit in, it also dodnt work. after all this i was determined to tackle another fuel pump swap, i replaced the carter with an AIRTEX unit, and now i cant even go to the hardware store cause the carb will dry out before i get there. i dont know what else to do, please can anyone help? i really love my girl and she's the only ''sunburst'' free wheeler i have seen with al the goodies, even ruise control. she is a beauty. please....anybody have this happen to them?
Hi DAS..,
WOW..! That is odd.
You may have a leak of sorts in the fuel line (between tank & pump) in that it sucks "IN" air, thus lessening the amount of fuel being sucked by the pump.
The only parts in that system are; the tank, pick-up tube, lines, switching valve, (if that rig has one) & the fuel pump......??
In rare cases a rubber gas line can seperate & suction causes it to colapse internally.
Another rare but poss. The cam lobe that runs the pump may be worn down & not giving a full stroke to the pump.
You could bypass the pump with an electric pump & see if that cures it.
HTH
fred tyler
