ford 9 inch
mark57
Does anyone know if a 9 inch posi rear end out of a 1970 Mercury will fit in a 1969 Bronco? It is a 31 spline. Any information would be appreciated.
Hi Mark.., welcome..!!! >:D< <'>
Basically, a 9" is a 9" ... however, your question is a bit un-clear. :unsure:
RU speaking of the WHOLE rear ... i.e. from drum to drum..?
Or just the center section diff. ??
If this is the case., then they should swap.
"It is a 31 spline."
Assume you mean the Merc. is a "31" as the Early Broncos came with 28 spline.
These must match. (meaning you'll need 31 spline axles)
Lastly., sometimes the "yoke" (where the u-joint locks in) is different & needs to be changed.
Also the "GEAR RATIO" must match your front diff.
Curious., what exactly is your goal here, with this swap...??
HTH
M
mark57
I am thinking a swap, drum to drum.
I can't help you there.... maybe someone else can.
The overall width may be dif., the spring-pad location & angle may be dif.
Shock mounts/lug pattern..? :unsure:
"9 inch posi rear end"
Being a '70 ...this (posi cutches) may need re-building as well. :glare:
OH..!! there's also small & large outer axle tube bearings to be aware of.
Elmo
Forsyth Georgia
Forgive me for stating the obvious but the mercury would be coil sprung and the bronco ( unless modified ) would be leaf sprung. This would have to be addressed in order to work in the bronco.
stevedave
