First Bronco
khanfam6
1 Month Unlimited Carfax VIN# check $24.99
Gas driving around for 1 month looking at
rust buckets sold as 'Good Condition' $150.00
Feeling of opening up 351 V8 on the
expressway going to work tonight Priceless
Just picked up my first Bronco. $3000,
94 E/B w/128k on the clock,all the candy.
No rust and needs new stereo.
Front end has a little play and fuel pump is whining.
Only one seen better than this was $6k;garage kept, 1 owner
trailer queen w/61k original miles.If it would've fit in garage, I'd own it.
Plan to keep 94/EB pretty much stock and use it as daily ride. 4x4 here is no more than
driving on city streets back and forth to work.
Newbie question about sway bars,and yes I will do a search now that I am regsitered.
Are they an easy DIY weekend project and will they improve
handling in the city ?
Will post pics as soon as my kids show me how.
Welcome to the Zone. Post some pictures when you get a chance.
You can get aftermarket sway bars for the rear end, but I don't know of anyone who sells aftermarket front sway bars for a Bronco. I have a set that I got from Jeffs Bronco Graveyard only takes a couple of hours to install them. I have had them on for several years now with no problems. They definitely improve road stability.
Installing front sway bars will probably require you to find the factory hardware. The main thing being the attachment bracket under the spring cup which also means taking the front end suspension apart to get them in. Fabrication of front attachment brackets is probably an option as well but I would prefer the factory brackets.
Sandoval_broncosauria
