early bronco
b6464
Hi Guys,
would anyone know that a 351 W- C6 conversion for an early bronco would be a good way to go or not?
And if so what would be a good transfer case match?
Many thanx.
Hi 64., welcome...!
Why sure...! That's the beauty on these EB rigs., you can mix/match anything you want fr. the radiator back to the rear axle/wheels. :D/
Somewhat because there's no 'puter or sensors to deal with..! All "old-school"
However., a lot depends on your intended use.
b6464
HI Bully Bob,
Thanx for the info. I was also wondering if you ve heard of big block 460 hook ups? If so, can a C6 be applied with the original transfer case?
Many Thanx.
An educated guess would be that the D-20 would be a bit weak behind a 460.
I would think an Atlas T-case would be in order.
However., another issue would seem to be a nose heavy condition in a short wheelbase rig. Likely need suspension & other handling mods.
The mix-n-match experts to talk to would be Advanced Adaptors.
These rigs don't need a lot of HP unless you're runn'n deep mud, etc.
b6464
Thanx for the tips Bully Bob. I be contacting Advance for the job.
stevedave
