drive train sound
bartowb
Cheyenne Wyoming
question for all of you out there. '69 has a tinny sound coming from the middle to rear of the vehicle when the drive train is loaded (accelarting) checked all the fluids and greased all the zirks and still have it. not sure if it is just me being paranoid or there is something going on? any help would be appreciated.
thanks
brian
Bronc76
You still may want to check out the rear shaft, even though you may have lubed it the joints may still be bad.
scrub
Ponoka, AB
Definately check the cv joint coming off the t-case. I had one seize up and take out the case.
bartowb
Cheyenne Wyoming
thanks fellas i will check all those things out. may just end up redoing all the seals and joints. we will see.
thanks again
brian
Sandoval_broncosauria
