Drive shaft help
russell
I need to get a -new/rebuilt/used- rear drive shaft for my 88 Bronco ii 4wd stick, 2.9l fi eng.
What years will fit mine. it has a 12/87 manuf date. what is the best way to measure the length needed.
What can I figure for a realistic price for the part if new/ rebuilt/ or used. Anyone have a useable one for sale, I'm in Sandpoint ID.
Bought the bronco last year, running fine otherwise.
First time Ive posted here, would appreicate any helpful info.
Thanks,
Russell
andre
gatineau hill quebec
you need to know what drive shaft type u got
old type u joint new type w rubber boots
get recondition about 120 to 140.00$ rubber type
u joint 20.00$ each x 2 labour about 20 min install around 80.00$
on my 1989 manuel trans the same then my 1990 auto trans
you can also swamp type but need ****** of the swamp you're doing
did it on my 1985 bronco 2 axel boot type know . was u joints
jerrybose442
Hey if you have the money I found that Bronco Graveyard had the cheapest prices and sells the conversion drive shafts for the BII. I just bought two different drive shafts from them and they work great. Just get rid of the cv joint axle, they always break.
Hope this helps.
Gary wilder
