Dead as a door nail
joe bronco
riverside, CA.
Hello,
Everything was going great with the restore until recently.
I lost all power to start, turn on lights, radio, etc.
I've checked fuses, connectors and battery. I have 5 fuses in the box instead of the 2 they show on the wiring schematic.
The wiring harness seems to be intact, the problem came on with no notice.
I'm wondering if a bad ignition switch could be taking everything to ground? Power is present with key in off position.
When you turn the headlight on I lose the incoming 12 volts at the fuse box, like a short to ground.
I'm going to start pulling connector and see if I can find the short.
Any and all help will be appreciated.
1969, 3 sp, 302.
joe bronco
BroncoJoe19
Sorry Joe, I don't have any documentation that goes back that far, so all I can do at this point is give you a little encouragement. It sounds like you know what you are doing but are just looking for a shortcut. Seems to me that you are going to have to start sectioning out parts of the wiring diagram.
Have fun... and good luck.
joe
J
joe bronco
riverside, CA.
Sorry Joe, I don't have any documentation that goes back that far, so all I can do at this point is give you a little encouragement. It sounds like you know what you are doing but are just looking for a shortcut. Seems to me that you are going to have to start sectioning out parts of the wiring diagram.Have fun... and good luck.
joe
Thanks for the encouragement it will be a process of elimination.
My 69 turned over once and went dead couldn't even jump it.
That's why I wondered how much the ignition switch has or could be a problem?
If I knew how to take it out would help a bunch?
Onward and upward.
later,
Stick a paper-clip in that 'lil hole & turn the key to access. then the lock will come out.
Un-do the benzel & the switch will come out the back. (be sure to un-hook the bat. first)
BUT.., a remote starter can hook to the sol. to by-bass the key. (good test)
Could be a fried starter causing the prob. as well.
1st. thing..., is the bat. 100%...??
jayjay
San Diego/CA
Sounds like a short to me.... Mine did that and I found a short going to my AMP gauge on my dash. I would go thru your harness and look for loose connections. Also I used to arc the solenoid with a ***** driver to bypass the starter in my 240z, maybe try that. If it starts you know it is your starter!
Sandoval_broncosauria
