dash lights
fordsohc46
fordsohc46
searcy, arkansas
my dash light don't work. i checked power coming from headlt. sw. and it has power and the dimmer is working at the switch. i was wandering if anyone knew which wire at the cluster connector gives power and ground for the dash light circuits. i have some powers and grounds at the cluster but not sure which pin is which. thks in advance for the help.
There is a fuse following the switch on the instrument lights. See the attached diagram.
gibs0n06
independece,mo
it a blue and red wire if you need more wiring diagrams autozone.com can help you they have helped me quite a few times
fordsohc46
fordsohc46
fordsohc46
searcy, arkansas
found problem the fuse wasnt making good connection. bent tabs that hold fuse in fuse box and now they work. thanks for the help guys.
